Recently I have been working on automating the process of blind spot analyzes in construction projects. In construction projects in order to analyze blind spot of equipment we execute 3D laser scaners. Then areas which are not visible to laser camera are identified as a point cloud. Is there any way to achieve that with vray?
vray irradiance map is some how so close to what I want. But unfortunately there are only visible from irradiance map viewer!
Then I have found vraysamplerinfo. nuke guys using this with RGB channel combination to create point cloud in nuke. But I don't know if there is any possibility to do the same in 3Ds Max!
I need to found a way to calculate blind spot percentage in order to complete my master thesis in construction management! I would really appreciated if any one could help me with this challenge.
Thanks
Thanks
