Irradiance x Resolution...
  • Irradiance x Resolution...
    Please...
    i have to do one pic with 2480 x 1744 but i dont know
    wich settings put in min and max rate in irradiance map...
    actualy i have testing with high (-3 and 0) but is very very slowly...
    anybody can tell me what can i do??
    thanx a lot
    do you have materials with glossiness?
      there is a rule of thumb .. but i just normaly render the image half the size, save the IRR map then render your image at the size you want from the saved map
      Natty
      http://www.rendertime.co.uk
        thanx... i will try... and will post result...
          Hey that's exactly what the min max settings do for you
          There's lots of info on www.vray.info about these settings.
            i actually find playing with the hsph subdivs and the interp amount can greatly reduce times allowing a higher resolution map to be created.
            when doing previews i use -3-3 (Antialising off)on the map and 15,15 on the hsphr and interp...when going to high res (4000x3000) i use -2,-1 on the irmap, wind hsphere up to 30 or 40 and interp from 50-100...antialiaing is 2 & 4, i find 6 is nicer but it has a noticable effect on rendertimes.
            I also force glossies to have one bounce.
            I found rendering bucket ir map would shave perhaps 10-20% off render time, but i couldnt guarentee i wouldnt see artifacting on the GI on where the buckets met.
            Digital Progression
