Hello,
I am trying some simple scenes with Vray.
I link a DWG in VIZ4.
Then I set all geometry to a default white material.
Then I set up Vray with default "medium" GI (I have the free version).
The geometry seems emitting light, as if it was fluorescent.
Very weird lighting...
Also, there are no lights in the scene, and when i go to viewport "configure", and use "standard light", one or two, I get totally different results. I thought those settings were designed for the real time preview only, and would not influence the renderings.
How do I disable those lights? (those may be causing the overexposed, fluorescent geometry). That is, how do I use ONLY vray GI?
Thank you
Regards,
Gio
Thank you
Regards,
Gio
