2 displacement modifiers?
  • 2 displacement modifiers?
    Hey guys am trying to do some displacement for a sidewall of a tire, the thing is i need 2 different maps, one that had negative displacement, and one that has positive displacement. I tryed using vraydisplacement modifiers but the dont seem to work together. i also tryed using Max displace modifier and nothing. Any ideas?
    PLAY
    www.kriscabrera.com
    kris@kriscabrera.com
    Hi, isn't it possible to use one V-Ray displacement modifier with Mix texture? It might be a bit tricky to adjust the negative part but the modifier has a Shift parameter.
    Best regards
    Alexander Kazandzhiev
    V-Ray for 3ds Max developer
      for 2 displacements you'll have to use max displacement as the base for the one, then on top of that stick a vraydisplacement for the other
      or use the mix texture, but like aleksander says, that might get a bit tricky
      Kind Regards,
      Morne
