Rendertimes topic
  • Rendertimes topic
    Hi fellow vray-ers!
    I'm working with vray for quite some time now at my job, but lately we seem to have some problems with render times. We have renders now that take 48 hours to render....
    So what I wanna know is....what are the main causes for long render times?
    -is it reflections? (we keep the subdivs very low...beneath 10)
    -settings? (our renders at work are usually around 4500 pixels...and we use default settings...usually irradiance map preset low.)
    -AA (we usually use adaptive subdivion)
    -something other than that?
    Just very curious what points at rendering take very long....So I can keep that in mind, so that maybe I could cut back on certain things..
    The problem is that we have some deadlines here and the renders take far to long to render...
    Here's an image of one of our latest work..This one also took pretty long, although it's not a very difficult scene.
    Thank you in advance!
    "Do...or do not. There is no try"
    do you use glossiness in your materials?
      Yeah I do...a lot actually.. All wood materials have reflections with glossiness.
      Is that a point where it slows down rendering?
        Looks like glossies are being used on the wood materials. This will jack up rendertimes greatly.
          Looks like you beat me to my previous post there.
          Yes, glossies will stretch out rendertimes dramatically in most cases.
          PS: Nice render though!
            So...if it's the glossiness, is there a way to solve it? To speed it up?
            Or is it impossible to avoid it? One thing is that I don't want to ruin my material..make it look worse. I want to keep te great glossy effects..
            Thanks!!
            Sebastiaan.
              maybe to work with blur maps?
              i rendered a picture with glossiness 1 in 1min30sec and the same picture with glossiness 0 (only one material in scene) in ~12min
                Does "use interpolation" make any difference with rendering speed?
                Sebastiaan
                  This is from the oldest manual I have...
                  "Glossiness - the glossiness of the material. A value of zero means extremely blurry reflections. Higher values makes reflections sharper"
                  so...
                  Glossy 1 = clear "Glossy" reflections
                  Glossy 0 = Blurry reflections or no Glossy.
                  --Jon
                    Sebastiaan
                    If you are rendering still images, try using interpolated glossies.
                    Open a scene you are having problems with, re-save it under a new filename and check 'use interpolation' for reflections for all materials where the 'glossiness' is not set to 1.
                    Then try the settings below for 'Reflect Interpolation'
                    http://vr.reaperfields.com/index.php...ile=RefInt.jpg
                    You could also try -2 for the 'Max Rate' which would be even quicker but with a reduction in quality.
                    Also, the GI presets are designed to be used for image sizes around 640x480. So the low setting is actually a very high setting for an image the size you a rendering.
                    Hope some of this helps,
                    Dan
                    Dan Brew
                      Sebastiaan
                      Greatly, Just leave it at 50 and check interpolation. This feature is specifically for stills.
                      --Jon
                        so...
                        --Jon
                        Uhmmm...yeah..I know this...that's not my problem.
                        Sebastiaan
                        Dan
                        He thanks a lot!! I'm gonna try that! Hope it helps. I appreciate it!
                        Sebastiaan.
                          No problem, thank me if you are happy with the result
                          Dan Brew
                            Sebastiaan:
                            That should have been directed at TOBTHREEDEE.
                            --Jon
                            • #15
                              Why?
                              Glossy 1 = clear "Glossy" reflections => fast
                              Glossy 0 = Blurry reflections or no Glossy => very slow
