how to avoid the dedtaching faces with displacement on...
  • how to avoid the dedtaching faces with displacement on...
    how to avoid the dedtaching faces with displacement on a brick wall ?
    Better How to do a brick wall with displacement without error on the corner?
    can someone help me?
    BYE AND THANKMS IN ADVANCE
    Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
    https://www.facebook.com/essetreddi..../photos_albums
    hi
    Tick Tight Bounds i do believe
    Natty
    http://www.rendertime.co.uk
      go here:
      http://www.seraph3d.com/bricktut.htm
      or use 3d mapping in the displacement options and check keep continuity
        THANK U VERY MUCH
        THANK U VERY MUCH FOR THE HELP
        to ALL
        AND TO NATTY
        To thanks for your help on reflect/refract Look at those images and tell me what do u think!!!
        http://www.treddi.com/modules.php?op...ff545a1e#19500
        I done this work with your help and suggest!!
        bye
          Brilliant work my friend.. well done
          Natty
            I think the top view of the spiral staircase is
            Nice work Pengo.
            Glad to see you have the same problems as me with glass becoming very dark when made thick
            Try an output map in the diffuse slot and put the color output on 1.05.
            You'll get all sorts of warning in the message box, but it'll look much better.
            Marc
              Hey Thank u very much
              You are too good with me !!
              I need to know more and more!!!
              I love vray!!!
              It's not the case but...
              Could u tell me if someone has hard disk crash with photon works?
              It's a strange question but with my 512 MB of ram I think It's not enough memory for this technique the swapping become so much and the hard disk work ever during night!!!
              Is it a problem that I could solve with more ram?
              I have two broken hard disk for high temperature now!!!
              bye and thanks in advance
                WOW pengo very cool
                How are you getting the variety of colors in the glass from the top view?
                Thanks,
                --Jon
                  thanks again
                  For the staicase materials I prefer the steel over the glass
                  2 J_Bug
                  I got those reflections with hdri in vray rendering rollout in the environment reflect/refract !!
                  the glass has 17 depth for reflections and the same value for refractions
                  bye
