Hints for stereo workflow
  • Hints for stereo workflow
    Hi all,
    recently we started working on a stereo project and for the first time we tested vray in this area.
    Everything looks fine, but i have a couple of questions about it that i couldn't answer myself looking over the forum or the user guide:
    - Is there a way to output the vray frame buffer as full screen?
    - Using the vraystereohelper can i output in any way two separated streams of renders (left and right) instead of a single doubled image?
    If not possible, these could be nice options to have in future releases.
    Thanks in advance,
    fede
    KCTOO - Directors
    You can maximize the VFB window and zoom in/out the output to match it to full-screen. Is there any particular reason why you want a full-screen preview?
    Currently the VRayStereoscopic helper can only output left/right/both(in a single image) outputs at a time. But I will forward your request to the developers for consideration.
    Zdravko Keremidchiev
      Well i know i could zoom in but that's not what i was looking for.
      Basically i'm previewing my renders (and comp) with a 3d tv and to enable a stereoscopic side-by-side view and i need a perfect fit on my second monitor. I can't achieve this with a manual zoom, also because i'll always have the vfb icons and stuff around.
      Thank you, it'd help as a general workflow i think.
      KCTOO - Directors
        Thank you for your feedback.
