Shadows
  • Shadows
    I render out a lot of passes, but to tell you the truth, I rarely use them. I want to de-saturate my shadows, and maybe saturate the lighter parts, but I can't figure out how to use my shadow pass. Do I need to crunch the white/dark shadow pass, or is there a more straight forward way? So, what I am asking, is how do I isolate just the shadows of my render in post?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Are you working with 32bit EXRs? If so, you should be able to get quite a long way with curves in photoshop.
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
      I didn't get anything from the shadow pass. I am using a 32bit PSD, but it wasn't of use.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        The best way to really utilise the shadow pass is if you have reconstructed the image from all your various render elements. That way you can add adjustments to the shadow pass layer independently. If you are trying to use the shadow pass in conjunction with an RGB base layer then all you can really do is darken the shadows by inverting the shadow pass and using multiply blending mode. You could also try using your GI pass set to lighten to lighten the shadow areas.
        I don't know if you use magic bullet looks in either Photoshop or After Effects, but it has a ranged saturation tool that can adjust saturation separately for shadows/midtones/highlights.
        Check out my models on 3dOcean
          magic bullet looks
          I had a trial, but it long stopped working, and it is so expensive.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            wouldn't rendering without GI work?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              It sounds like you want the "matte shadow" pass rather than just straight shadows. This'll give you a matte of any shadowed areas.
