DR with Max Populate High Res feature
  • DR with Max Populate High Res feature
    Can you use DR when populating a scene with a crowd using the Poplulate (high res) feature of Max? I have not been able to get it to work so far. Now I am using the "populatehighres" installer on all of my slaves to see if that will get it to work. Will that help?
    Daniel Black
    Archtagon LLC
    www.archtagon.com
    Yes this is what you have to do.
    In addition to a higher res mesh, the high res installer installs slightly higher res textures. So to render correctly you have to install it on all slaves
    To be honest they should have called the default one "low-res", and the high res one they should have called "medium res", in my opinion
    Kind Regards,
    Morne
      You will also have to re-path your temp folder to one that can be seen by the network. The maps for populate are generated "randomly" when you simulate the people, these maps are stored in the max temp folder. The DR slaves will need to see those maps.
      jhv
        Thanks guys. Very helpful!!
        Daniel Black
        Archtagon LLC
        www.archtagon.com
          Oh...how do Repath the temp folder?
          Daniel Black
          Archtagon LLC
          www.archtagon.com
            Customize -> Configure System Paths -> Temp
