DaylightSystem and VrayLightSelect
  • DaylightSystem and VrayLightSelect
    Quick question... I have a VraySun as part of a daylight system. Is there a way to add that sun to a VrayLightSelect render element?
    Thanks,
    Travis
    Can you not just pick the sun? Worked fine in my quick test.
      Attached is a screenshot of the results I am getting...
      When I hit add and try to click on the Daylight system I wind up getting the Sky002 instead of the VraySun.
      I also tried to launch the select object dialog and select the VraySun but it is not listed because it is part of the daylight system.
        Set the sky in the daylight system to <No Skylight> - then you will be able to pick the sun.
          Thanks......
