I am rendering out still for an animation, but it's not saving it with the gamma. The save dialog box has the gamma grayed out, so how do you save with gamma 2.2 applied? I have been doing it in post, but I shouldn't have to, correct?
MAX 2014 Gamma out
MAX 2014 Gamma out
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
fileOutGamma
1.0Bobby Parker
phone: 2188206812
- Windows 11 Pro
Welcome to automatic gamma land!
It depends on the format you are saving your images as to what gamma max "automatically" applies to it.
If you open up a max scene that is saved with 2.2 gamma you will notice max asking you whether you want to use "from file" or "system" settings. If you use the file settings with 2.2 gamma as the output gamma it will then change your system output gamma to 2.2 in 2014.
After you do that if you just need to be careful when you open a new scene that you use "system" and check that is says 2.2.
Annoying right?
Yes. I have been doing it in After Effects. So, there is no easy way to save a jpg with gamma 2.2? I tried tiff and tga, too, but that was grayed out.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I tried a script, but it really mucked things up, so bad that I had to recover a backup.Bobby Parker
phone: 2188206812
- Windows 11 Pro
good to know, thanks. I'll keep it at 1, because usually that is what I want, but this time was unique for me. It's odd that we don't have the flexibility to control our own gamma anymore.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Odd, mine is grayedBobby Parker
phone: 2188206812
- Windows 11 Pro
rendering out stills is when I am seeing it grayed out.Bobby Parker
phone: 2188206812
- Windows 11 Pro
