Vray or Max bug?
  • Vray or Max bug?
    Hi! I'm using a script that with an attribute holder on point object, animates the hide and unhide of objects, I'm using that because the regular visibility track does not really hide the object from the viewport and I need to hide it completely.
    The thing is that is works fine on the local machine, but if I turn ON distributed Rendering, the objects do not really show up on the tiles coming from the other computers, I just see the background, and in the logs on the remoter computers, the objects are not even mentioned when lists the geometry being rendered...
    I'm not sure how Vray DR works.. Does VR sends the whole scene to the other computers or just send the objects opened in memory in the main computer? Not sure how to discover if this is Max fault or Vray...
    Thanks. I can send an example with the script.
    It would be best if you can get us a scene to vray@chaosgroup.com for investigation.
