Deciduous Trees w Twinkle Lights?
  • Deciduous Trees w Twinkle Lights?
    Quick question... does anyone know if a 3d resource for deciduous trees that wrapped in twinkle lights? I would rather just buy some nice ones than to spend time wrapping them myself.
    https://www.google.com/search?q=tree...bih=1035&dpr=1
    Have you tried duplicating the trunk, adding a push modifier & sticking a cellular in the opacity slot of a vray light material? Playing around with the spread & thresholds of a cellular map gives a pretty good result.
      Solid idea. I'll give it a go.
      We are also tossing around the idea of using multiscatter on the trunk and branches.
        Scatter would work, unless you need to see the lights connected by a wire, then its kinda hard
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          Nah... no wire needed. This is a competition image so it is more about impression than making sure every detail is in place.
            Then even simple static particles/geo_instance would do the trick.
            Dmitry Vinnik
            ShowReel:
              Yes we do similar stuff all the time. Stick a particle cloud in there on vertex mode and use a spherical vray light.
              Kind Regards,
              Morne
                I've used a similar approach in the past to scattering, but rather than using the trunk and branches, I manually made a proxy that touches the outside of the tree, and used that as a base to scatter. This is because most lights only sit on the outside of the tree, rather than going inside.
                Dean
