RGB and 2.2 Gamma
  • RGB and 2.2 Gamma
    is there an easy way to convert RGB colors values to show up correctly in 2.2 gamma?
    I appreciate any suggestions!
    -Eric
    "I have not failed. I've just found 10,000 ways that won't work."
    Thomas A. Edison
    If I understand your question, what I do is, use a vraymtrl to do the conversion. I type the RGB value, set it to .4545, and copy the converted swatch to the MAX slot.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Or you can use a VRay color map and put in the correct RGB values. Then set the color space to 2.2 and it does the conversion for you.
      Troy Buckley | Technical Art Director
      Midwest Studios
        That works Thanks!
        Thomas A. Edison
