We are trying to render out an animation (arch. fly-by) using a saved irr. map. We calculated the map first using multiframe incremental, every 20 frames. Then we set the first computer to render the whole sequence from frame 1. Then we loaded up the same scene on 2 other computers and set them to render frames 200-300 and 301-450. We rendered out the first frame so that there would be an irr. map in memory, and then we set them to render the remaining frames using the saved irr. map. The first computer is still rendering out the frames perfectly, but the other 2 are somehow not correctly using the saved map because there are splotches all over the place.
Can anyone tell me what we're doing wrong??
Thanks!
John Pruden
Digital-X
Thanks!
John Pruden
Digital-X
