Need help with saved ir map...
  • Need help with saved ir map...
    Hi all,
    i'm working on an interior scene with some glossy reflections ,i've calculated the scene and saved ir map but when i switch to saved map and hit render , still needs to calculate and prepasses that took alot of time and didn't went through render.
    am i doing something wrong or is it normal???
    Thanks..
    its calculating the interpolation from your glossy map. dont set it to interpolate in your material and it wont do that.
    percy
      Thanks for a quick reply percy.It works and you really saved a lot of time for me.Thanks again
        no problemo
          oh, cool - i never knew thats why it added more prepasses even when irr. map was calculated already.
          Tim Nelson
          timnelson3d.com
