Spawner starts several time
  • Spawner starts several time
    I´m new here in this forum.
    My problem is the spawner for distributed rendering.
    Everytime when I doubelklick the spawner-icon, the spawner start a several time.
    It doesn´t end with starting the spawner.
    At least there are a lot of spawner icon´s in the taskbar.
    Have anyone an idea wath I have done wrong ?
    Thanks for your help
    Batch
    I have exactly the same problem. Spawners keep opening in the taskbar until there are hundreds of them and my system crashes. I can't stop them!!
      is the spawner already running as a service ?
      Natty
      http://www.rendertime.co.uk
        No, it runs in normal mode
        Batch
          have you uninstalled it then reinstalled ?
          Natty
            I erased the vray files out of the max and plugins directory.
            i haven´t found the reinstall-function.
            After erasing the files, i drive my computer done and started it again.
            Then i installed vray new and the same action was to see.
            By the way, excuse for my english !!!
            Batch
              hard to say, but reinstall your max and it should work again. worked for me serval times.
              http://www.eldaco.net
                I don´t think, that it´s a mistake off max.
                On one of my other maschines, it´s still the same !
                Batch
                  OK guys, here i´m back and i must say sorry that i steal your time.
                  This is whats happend:
                  1. installing Vray
                  2. run DRwizard
                  3. set normal Mode
                  4. Set directory: and here is the stupid mistake !!!
                  In the Applikation folder i clicked on the "VRaySpawner50.exe" and not on the "3dsmax.exe"
                  Now the Spawner starts only one time.
                  I think that i have to learn a lot of vray
                  Thanks for your help.
                  Chocky, i hope you can do something with my issue.
                  Batch [/u]
                    lololol woops
                    Natty
                      Thanks Batch,
                      I made the same mistake as you. All fixed now!!
