VRay Render Optimization
http://www.CGGallery.com/tutorials/vray_optimization/
There can often be a lot of confusion surrounding the topic of V-Ray's sampling and what 'ideal' settings are. Many times you'll see artists adopt the 'Universal V-Ray Settings' of having the Image Sampler (Anti-Aliasing) Max Subdivs value set very high (like 50 or 100), and then simply lowering the noise threshold value until the render becomes clean enough - thinking that it's the best / fastest that V-Ray can do. But with a bit of understanding of how V-Ray works under the hood, you can achieve a higher quality result WITH faster render times - in some extreme cases nearly 3x faster than the universal settings can give you.
This article is designed to be an essential, step-by-step guide on how to Optimize any render in V-Ray.
I've tried my best to make the information as simple and clear as possible for a complex topic like this - but there's always room for improvement.
So I'm sharing it here first with the V-Ray community for a bit of feedback and discussion. Take a look, try it out, share your findings, and please let me know if you have any feedback!
I'm also planning on adding some production Before/Afters to the article later this week, so if you can, share your Before/After images!
Hope it helps - Happy Rendering!
