Clouds & Vray
  • Clouds & Vray
    Can anyone from ChaosGroup or the public answer this? I've been waiting for a simple solution for years to creating clouds in 3D Max and Vray but the only ones that really exist are:
    VRayEnvironmentFog - But it's very complex to get a good realistic cloud system generated and can take hours or even days trying to get something to look decent.
    Ozone or Vue by EOn Software - Looks great, but appears to not be very friendly when using custom gamma or linear workflow and really effects lighting on your scene. Especially if you have interiors involved. Is this still an issue?
    HDRIs - Obviously as real as it gets, but some cases animated clouds, flying through clouds, or passing clouds is desired but can't be achieved using this method.
    Phoenix FD or FumeFX - Not designed for clouds, but can sometimes create really nice dynamic clouds at the cost of really high render times. Personally I think Phoenix FD should have a cloud system added on like they added Ocean and Water.
    Sky Maps - Last resort if nothing else is available, but it's not as good a HDRI.
    Am I missing anything that's new or better for creating clouds with VRay? It's 2014 and it appears clouds is still an issue for 3D Max and Vray. I know Maya has a quick simple cloud option in the Visor section. Nice looking clouds in like 3 clicks and a spline. Why can't Max have something like this? Any suggestions?
    it's not limited to max and vray, it's just really difficult to do. I know of maya's fluid option but I've never seen a render of them that looked good, all the tutorials look rough.
      For Maya I said the Visor Clouds. I've seen some really nice results with this.
        I've never tried it, but has anyone ever got decent clouds with Phoenix FD? At the very least it ought to render fast with VRay
        http://www.glass-canvas.co.uk
          Here's an interesting tutorial on doing clouds in Maya: https://vimeo.com/30189748 (not VRay)
          - Geoff
            Here are some tests with Maya fluids.Click image for larger version
              Afterburn can make some cool clouds. I've used it a few times.
                I did a while back. It's tough to get the sim right because clouds are all about vapor condensing etc. If you get your data right it would prolly render okay. Here's a bit of discussion:
                http://forums.chaosgroup.com/showthr...-using-phoenix
                Cheers,
                Thorsten
                  There is a method for creating clouds with image planes. Create a blocked out shape for the clouds with solid geo, bake your GI to vertex color and pass that along to planes scattered over the surface. Renders in scanline and is pretty fast.
                  http://www.klaasnienhuis.nl/2011/08/...platige-image/
                    I saw this ( http://www.quadspinner.com/helios/ ) mentioned a few times when people were talking about clouds but since I don't have Vue I can't really give any feedback on how well it works. The pictures on their homepage look impressive though.
                    Cheers,
                    Oliver
                    https://www.artstation.com/mokiki
                      It's a series of presets for vue effectively, or a nicer ui that links together some fractal settings that give nice results in vue. You still need xstream to use it inside of max so it gets quite pricey, can't argue with the results though!
                        It looks great, but $500 for the main functions and $1000 to get render passes on top of vue is pretty steep. I'm just sad i wont get to play with it, it's a no brainer for aerial vfx work
                          The below shot was done with Vray Evironment Fog and took 1 minute 40 seconds to render on an older 4-core i7.
                          If by any chance it interests you, I'd be happy to upload the file..
                          -Alan
                            Yes, please.
                            • #15
                              yes - we have created some lovely clouds with Phoenix FD.
                              We also used Vertex colour mapping successfully for a recent animation
                              What we have found for some instances is create basic geometry cloud shapes, export to After Effects as an OBJ and uses Red Giant Trapcode Form.
                              There are some tests on our blog - http://fingerindustries.wordpress.com/ but not got around to adding most of the above mentioned as yet!
                              Cheers
                              Marcus
