I saw a post a little while ago about problems with smoothing on bionatics trees. it seemed that there was an issue with vray - that was preventing the smoothing from working.
anyways, i tried applying a smooth modifier but that doesn't seem to work. the only work around i have found is to first weld all the vertices, then apply the smooth modifier. the problem is, some of the tree models are too hi-res, so welding all the vertices just crashes (or freezes) MAX.
any other options? is there a fix in the works with vray that will solve this?
sean
sean
