distributed spawners: resolve server shows wrong ip
  • distributed spawners: resolve server shows wrong ip
    Hey folks,
    again I have the problem on one spawner machine and can´t find a solution (as i now would like to avoid a reinstall): the spawner machine name is correct, it´s ip is defined by the dhcp-server and shows up correctly in the domain but "resolve servers" still shows the wrong, old static ip and of course of that the workstation can´t connect to this spawner. all other spawners work fine with machine name and dynamic ip. when adding this malfunctioning spawner via correct ip and not via machine name to the spawner list it works fine.
    By the way, the "Status"-Column is completely empty, is this correct?
    As i have dhcp-server i don´t want to use ip but machine name.
    Somewhere the old wrong ip seem to to be kept and the new dynamic ip ignored.... any idea?
    Matthias
    Make sure that you haven't got any association between computer-name and IP-address in windows-host file located under the following dir:
    C:\Windows\System32\drivers\etc\hosts
    Also please try to remove this computer from DR-settings and add it again.
    If the issue still persist please contact us at support@chaosgroup.com and include a link to this thread.
