I posted the below and then ran some more test.. this image was done without photon. I have rendered many test on the int and many on the ext and I could always see the outside including the skydome.
I think it may have to do with the fact that before I was using the default light and after some advice from others as the the flatness of my rendings, I no longer have the default on. Is there a way to light up the skydome and surrounding areas? I tried to place a vray omni and only have it effect the skydome.. it did not work and I also have other areas I need to light..
Thanks for any help.
Michael
I am try to learn how to use photon and I have a model that I have used a skydome to create the ext. When I render the interior, the ext that does not fall with the direct light that I have for a sun does not show up in the render, in effect I get a night shot. I tried to add a vray omni and just have it effect the skydome, but that did not work.
I have a large garden and pool that are modeled that must be visible from inside the building. Can I use photon and still have a good rendering of the ext area? I have found that I can render much faster with photon...
thanks
Michael
Michael
thanks
Michael
