How do I achieve this finish in Vray?
  • How do I achieve this finish in Vray?
    Really struggling with creating a rug as in the attachments.
    I can get the vray fur to get sort of the right shape/orientation. But its probably not 100% there.
    The more difficult part is the material. Getting that change in colour and sheen on the fur. I cant get anywhere close.
    Any ideas?
    I never attempted to do a rug like that but if you're using vray fur you could make use the of the feature where the fur picks up the color from the texture of the base object. That way you can get some color variance by using a noise map for example. For the sheen did you try playing around with falloff map in the color or reflection slot?
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
      I did try both falloffs yes, cant seem to get such extreme differences without it looking rubbish.
        I had a quick go with it during lunch and you are right its pretty tricky to get the falloff curves right without it looking awful from all directions. Definitely more complicated than I thought. On the other hand I totally forgot about the vray hair mtl I think that should get you pretty close at least it looked promising during my 1 min playtest.
        Cheers,
        Oliver
          I was hoping the hairmtl would save the day, but I cant get a good result from it.
          User error Im sure...
            Ok went back to Hairmtl again. Turns out I should have been using BF. So this is where Im at (attached)
            Colour needs to be tweaked, but there's no sheen at all. There are a set of plane lights in the ceiling which I feel should contribute some specular?
              You will need to increase the glossiness for the primary hilight, I guess. Also, smaller lights will produce better defined hilights than larger lights.
                In the past i've used fake lights with an include on the rug and only affect specular turned on. Totally faked it, but worked. My material was also set up with additive blends to push the specular to unrealistic levels
                I also did it using geometry and forest pro - the geometry was all bent over to one side with rotation/sheen patches handled through a noise map in forest. that probably doesnt make a difference at the end though
                Still wasn't ideal, but might be worth mixing some of that in.
                  Just noticed I forgot to attach an image to my last post:
                  I know the fur still looks "rough"
                  Cheers,
                  Oliver
                    I got some great results using the VrayFur Styler - http://help.chaosgroup.com/vray/misc/
                    Taking Vlado's advice I added a few point lights (1 warm, 1 cool) - there's also an HDRI of an interior for subtle reflections - used the VRayHairMtl with the default 'brown shiny' & a fur texture, 50.0 in the diffuse.
                    The styler is what really does it, just sweeping around the brush to get those hairs going in different directions for catching the light just right. For that rug I'd break it down into square patches and do this -
                    protip: I had to collapse the stack on the geometry reference to get the VrayFur Styler to update in the viewport in realtime - otherwise each time I opened the scene the update would be visible
                    protip2: when happy with the results - collapse mesh completely to keep the vertex channels but remove the modifier so that you can render without issue on other machines (or install VrayFur Styler on all nodes...)
                    Brendan Coyle | www.brendancoyle.com
                      Heh very cool Glad that it worked out well.
                        I really wish FurStyler was in VRay as a default. It's not currently available for Max2014, and really should be native with the vray installation.
                        Colin Senner
                          Totally agree - although this is only the second time I've dug it up to try and use it. It does a fantastic job of helping make those hairs look somewhat presentable
                            Thanks for mentioning that plugin. Haven't heard of it before
                            Cheers,
                            Oliver
                            • #15
                              It's not recompiled very quickly per max release. Recompile for 2014 x64 sometime please .
                              Colin Senner
