How to access material properties via Maxscript
  • How to access material properties via Maxscript
    Hi all,
    I'm hoping this is very easy and I am just being thick, but I seem to be unable to work out how to add a texture map to the diffuse channel of a Vray material via Maxscript. Is this easy enough?? Basically I want to add maps to diffuse and opacity automatically. This is how I am adding it when using a standard material :
    theMaterial.diffusemap = bitmapTex bitmap:theMap
    Any help greatly appreciated.
    Paul
    You can use the showproperties MaxScript function to list all available MaxScript properties of the V-Ray material. For the diffuse texture in particular, you could use something like this:
    Code:
    theMaterial.texmap_diffuse=bitmapTex bitmap:theMap
    vlado
      To show the properties of a material in the first slot of the material editor type this is in the listener window
      show meditmaterials[1] -- ([1] is the slot number that you want to see the properties for)
      Once that shows you'll see down the list :
      .texmap_diffuse : texturemap
      .texmap_diffuse_on : boolean
      .texmap_diffuse_multiplier : float
      .texmap_reflection : texturemap
      the property texmap_diffuse is what you're after, you'll see it takes a texturemap as an input.
      Colin Senner
        Thanks Vlado, i'll try that..
          Thanks Moondoggie,
          That's exactly what i needed..
            Just for "best coding practices", it's always best to test to make sure a property exists before attempting to change/set it. For instance
            Code:
            mat = meditMaterials[1]
            if (isProperty mat "texmap_diffuse") then
                -- change or do something to the mat.texmap_diffuse (like assign a new bitmap texture)
            else
                format "Mat: [%] does not have a property 'texmap_diffuse'\n" mat.name
            Colin Senner
              Oh ok. Thanks for the tip..
