Sp 5
  • Sp 5
    http://knowledge.autodesk.com/suppor...ce-pack-5.html
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    thanks for the heads up. Surprisingly quick after SP4, didn't expect them to fix things in 2014 any more with 2015 around the corner. Sadly there's no mention of them fixing the shift-drag clonebug in the list of fixes. Would be nice if 2014 was fully functional.
      I cant believe that bug exists still. Pretty poor performance on AD's part.
        Seems gone to me. At least I havent been able to reproduce it since SP4...
          I think there is a mention of shift-drag with splines being fixed ?????
            Wow. I can actually use a HDRI environment and see it in the viewports now in Nitrous.
            I feel like we have rediscovered fire.
              I think the shift-drag Cloning bug was fixed in SP4 actually.
              Alex York
              Founder of Atelier York - Bespoke Architectural Visualisation
              www.atelieryork.co.uk
                Since the last releases take 30m or more to update, i start using the comand line to install.
                After some tests, i got to install SP5 in 15s (SSD drive) instead of 30m, using a elevated command line.
                Here what i used.
                msiexec /update 3dsMax2014_SP5.msp /quiet /l* update_sp5.log
                Daniel
                Daniel Santana | Co-Founder / Technical Director
                You can do it! VFX
                Lisbon/Porto - Portugal
                http://www.ycdivfx.com
                  Here what i used.
                  Daniel
                  Sweet tip there santana
                    anyone else having issue installing it on windows 8? works fine on windows 7
                    jhv
                      Nice one. This annoys me every time
                      Nils Poetoehena
                      3D Visualiser
                      www.demanufacture.org
                      www.gielissen.com
                        Here what i used.
                        Daniel
                        Superb - thank you! The update took less than 1 minute on my SSD. Must remember this for next time.
                        Alex York
                          Here what i used.
                          Daniel
                          Buy this man a beer!
                          Am I right in presuming that if you delete the "/l* update_sp5.log" then it won't create a log file?
                          http://www.glass-canvas.co.uk
                            Send me the beer by email . Yes the "/* update_sp5.log" is not needed, is just for those who want to check what happened.
                            Daniel
                            You can do it! VFX
                            • #15
                              Here what i used.
                              Daniel
                              Nice!...can anyone help be get this running in a .bat file? so far I'm not having any luck.
                              "I have not failed. I've just found 10,000 ways that won't work."
                              Thomas A. Edison
