Titel says it all...
We usually only use the clamped Output, because we often had issues with fireflies (I know Vray 3.0 has that new feature for firefly reduction, but I couldn´t get it to work properly yet).
So I have a whole bunch of files clogging the hardrives, that I always need to delete after rendering (16 bit tif files in stereoscopic 1080p tend to quickly fill up space...).
So is there a way to only save out rgb channel, but not real color?
Another nice feature would be to be able to save out the render elements in different folders via the frame buffer, is that a max restriction or would you consider adding that feature?
