Tree optimization
  • #31
    So here are a few of my tests (done with V-Ray 3.0 though, and note that I do not have Autograss on that machine):
    The original image, rendered in 1h 18m: https://ftp.chaosgroup.com/vlado/ima...e/original.png
    The original image with "Affect shadows" enabled for the glass rendered in 1h 10m: https://ftp.chaosgroup.com/vlado/ima...riginal_as.png
    The image with my settings (min shading rate 16, global subdivs multiplier 0 to remove any subdivs anywhere else, max ray intensity set to 20, and AA color threshold 0.007), rendered in 18m 30s: https://ftp.chaosgroup.com/vlado/ima...univ_16msr.png
    As you can see this one has very similar quality and better AA overall. The shadow wall is perhaps a bit noisier and this can be fixed by decreasing the AA color threshold a bit.
    The next image is with Embree enabled and rendered in 14m 8s: https://ftp.chaosgroup.com/vlado/ima...msr_embree.png
    Here another test with the trees visible to GI, as they would be by default, rendered in 14m 57s: https://ftp.chaosgroup.com/vlado/ima...6msr_trees.png
    So turning ON "Visible to GI" adds a bit of render time, but not that much, so I don't know if it's worth it to go and disable it in this case.
    There's a trend with most of the scenes I've been getting lately; switch to BF+LC, ignore any subdivs anywhere the user might have set by putting 0.0 for global subdivs multiplier, and then playing with the min shading rate (8 or 16 seems to work fine for most cases) and the AA threshold to get what I need - in most cases turns out way faster than what the user had originally by playing with subdivs all over the place.
    • #32
      But, having said that, they are red as heck on the sample rate map.
      Does it matter if they render fast
      • #33
        fast and good!
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
        • #34
          okay, I am impressed. Everything is rendering in real time (dragging my mouse across the vfb) and it is clean. Even the motion blur renders fast!
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #35
            Just a note. The only way to really set the Global SubD multiplier to 0.0, his maxscript (renderers.current.dmc_subdivs_mult), correct? At least i got a 0.0000001 when using the UI.
            Maybe you guys should set the min value of the spinner to 0.0?
            Daniel
            Daniel Santana | Co-Founder / Technical Director
            You can do it! VFX
            Lisbon/Porto - Portugal
            http://www.ycdivfx.com
            • #36
              Vlado,
              does this mean the AA min is 1 and AA max is 100, as specified in the universal settings? All other settings for BF and LC are default? Sounds interesting.
              • #37
                Very intriguing stuff...
                Originally posted by kosso_olli View Post
                Vlado,
                does this mean the AA min is 1 and AA max is 100, as specified in the universal settings? All other settings for BF and LC are default? Sounds interesting. Got a car interior which is mostly black. Dark upholstery, black ceiling etc. Getting it clean is quite difficult, will give your settings a try tomorrow. Anyway, thanks for sharing your insights.
                • #38
                  Originally posted by dgsantana View Post
                  Just a note. The only way to really set the Global SubD multiplier to 0.0, his maxscript (renderers.current.dmc_subdivs_mult), correct? At least i got a 0.0000001 when using the UI. Maybe you guys should set the min value of the spinner to 0.0?
                  Yes, will do that. But 0.0000001 does practically the same thing for this scene.
                  • #39
                    Vlado, does this mean the AA min is 1 and AA max is 100, as specified in the universal settings?
                    [EDIT][EDIT] (too many scene files ) Yes, they are 1/8 as they were originally in the scene. Will do a 1/100 to compare, but even with the universal settings, you can usually get away with lower values and still get a good image.
                    • #40
                      Here is a render with 1/100; as you see it took a bit longer (20 min), but still not as long as the original settings.
                      https://ftp.chaosgroup.com/vlado/ima...bree_trees.png
                      • #41
                        max ray intensity is a VRAY 3.0 thing, correct?
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #42
                          Yes it is.
                          • #43
                            I've tried running a scene thru this (difficult light, lots of materials that I really dont want to have to optimize, lots of very glossy reflections) and this "workflow" is powering through the render. I'm quite amazed so far. Vlado, do you have any tips for fine tuning. I'm aware this is a sort of universal method but I've been throwing seemingly random settings at it not really knowing whats going on under the hood. What's the relationship between the max aa subdivs and min shading rate for instance? Should we be unlinking the clr thresh and noise thresh for greater control? I guess the setting that seems to be most mysterious to me is the min shading rate...
                            • #44
                              I have been using the method, and like you said, it eats right through the scene. It is pretty remarkable that one or two spinners simplified the workflow.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #45
                                You're using vray 3, right?
