Shadow Recieving Matte for Ground Plane
    Hmmm. Ok, I get what's happening now. Unfortunately, it won't do for what I'm trying to do. I'm basically trying to catch the shadow on a plane, and then still see anything below the plane (whether that be a light or another object), just with a shadow overtop. I'll have to do some rethinking of how I'm trying to achieve my goal. Anyways, thanks for all the help!
    - Neil
      ... but that´s exactly what it does.
      put an object below the plane
      the plane catches the shadow of the light
      and
      you see the object or a light below the plane
      no need to rethink
      if you want the dome light with a map it´s ok (invisible) and put a instance of the map in the background
      Klaus
        Not sure if this helps but if you:
        1. Add a white material to your plane
        2. Bake out your lighting for this plane
        3. Re-add your environment image to your plane
        4. Then divide this environment image by your baked light map for your plane shader
        You can add objects and get the correct shadowing. I haven't tested this enough yet though to figure out whether the result is the same as using a material wrapper.
        Win10 x64, 3DS Max 2017 19.0, Vray 3.60.03
        Threadripper 1950x, 64GB RAM, Aurous Gaming 7 x399,
          and
          no need to rethink
          Klaus
          That's not entirely true - when a camera ray hits matte object it omits every geometry behind it a reaches directly to the background. You can control object visibility in the alpha-channel via Alpha Contribution parameter inside WrapperMtl but not in the beauty-pass.
          The only option would be to bake the matte-shadow-map and then use it into opacity slot of the ground material without matte-properties.
            Here you could find a single-pass solution which will work with standard Max-lights but not with VrayDOmeLight.
            http://forums.chaosgroup.com/showthr...392#post611392
            • #21
              Yup, so objects below the plane (real objects or lights) don't appear.
              - Neil
              • #22
                Thanks, but unfortunately I need something that works with vraylight in dome mode. Maybe I'll add something to the wishlist.
                - Neil
                • #23
                  Thanks for the suggestion, but I need a one click solution for this particular application. I'm not trying to get a specific file working, I'm trying to come up with a generalized material that can be quickly assigned to anything and it just does the right thing. So I may be out of luck.
                  - Neil
