Vrmap question
  • Vrmap question
    Hello all,
    I rendered out a vrmap using the every 10th frame method but I have a question. For most of the animation, all of the objects are static. There is a short section of the animation when a pair of doors opens up into another room. Is there a way I can go back and render those few frames (every frame) and add it to the overall map? Can I use the "add to current map" without messing up the vrmap I just rendered?
    Thanks
    Scott.
    you'll have to render that sequence seperately with its own irrmap calculated each frame
    moving objects will corrupt your irrmap
