Fresnel by default - aaahhhgggg!
  • Fresnel by default - aaahhhgggg!
    Lost count of how many times this has caught me out now.
    "Why are my reflections so weak? I'm sure my falloff should give me stronger reflections that this!"
    <Modify falloff curve>
    "Why are my reflections still so weak? I'm sure my falloff should give me stronger reflections that this!"
    <Realise fresnel is ticked by default>
    "Arse!"
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    You'll get used to it It's one of those things where we knew we had to change it sooner or later, but we've been putting it off for too long for exactly the reason that you mention.
      By contrast, I've had this
      "Why are my reflections looking so good straight away? I'm sure I forgot to enable fresnel..."
      "Hooray!"
      MDI Digital
      moonjam
        Everything has fresnel!
        Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
        www.robertslimbrick.com
        Cache nothing. Brute force everything.
          I'm using multi-layer falloff curves though, so fresnel isn't needed.
          Kind Regards,
          Richard Birket
            I've never really understood the hangup with people insisting you use falloff curves for reflections. Perhaps it's because I grew up doing 3D's in an era where fresnel was available in most render packages.
              Its such a big time saver when creating basic materials.
              Chris Jackson
              Shiftmedia
              www.shiftmedia.sydney
                Not really much of a hangup. I've used fresnel myself mostly but we are always experimenting and trying new methods. Falloff certainly has advantages with controlling reflections at particular angles and also in colouring reflections.
                Kind Regards,
                Richard Birket
                  Could you expand more on this please.?
                    i think he is refering to the same approach creating a custom BRDF as described in Grant Warwicks material tuts??
                    Martin
                    http://www.pixelbox.cz
                      I believe he's meaning he's using a falloff map to create a custom fresnel curve, rather than just specifying an IOR number with fresnel enabled in the material.
                      Akin Bilgic | CGGallery.com
                      Modeler & Generalist TD
                      V-Ray Render Optimization
                      V-Ray DMC Calculator
                        See I have the opposite reaction every time I open something that uses falloff curves instead of fresnel. This ain't 1999, do your research and use proper IOR values (is what I say to the imaginary asset creator, not to the OP specifically).
                          This is kind of true, however there's a certain amount of artistic license that can go into these things too. If I've a static scene or a particular lighting scenario, I'll often use a falloff curve that looks very similar to a fresnel and then tweak the curve a tiny bit to have a bit more performance - I might want to get a really nice roll-off between reflective and not as an example. The thing with real data and accuracy (which is typically what my day to day activity is) is that you can replicate something really accurately, but accurate / real can sometimes look a little underwhelming. If you're doing cg for live action integration for example, the DOP may have put in some additional lights or bounce cards if the objects had actually been there on set for him / her to see.
                            I'm voting against the fresnel default, because I too keep getting caught out on the change. But I guess I'll get used to it. I know it's more accurate, but you just get used to doing things a certain way (and I've been doing them for a long long time), and change is hard.
