Rpf image with vray in comustion3 doesn't work Right...
  • Rpf image with vray in comustion3 doesn't work Right...
    I have a problem saving files in .rpf format ,rendered with vray and max6,
    when i import the fotage in combustion 3 , i cant view the separated objects.....
    I enable every channels in the gbuffer pannel..but noting ..
    When i render with the standard Scanline, works fine..
    Please help me.
    Thanks
    vray does not support combustion at this moment. See this thread.
    http://www.chaoticdimension.com/foru...5256&highlight
    They say the 1.5 build will have render passes. Gadzooks
      Thank you.
        Works Here...
        Eric Boer
        Dev
          Here is a Vray rendered RPF in combustion.
          Eric Boer
          Dev
            Yest it works, but u cant' select ( in ur example) only the Cilinder, or onli the box ..
            U have the wole image ....and not the separated objects..
              Sorry, I misread the first post, you meant like this
              Eric Boer
              Dev
                I mean like this., image rendered with max scanline..
                One rpf image, and i can select every single object..
                CopyandPast this http://utenti.lycos.it/asd1/C3rpf.gif
                  oh that, yeah layers are not supported, but using G buffer extract gives the same result, just a bit more work. I wouldn't say compositing with vray does not work...
                  Eric Boer
                  Dev
                    Yes, sorry, wrong title....
                    I'll change..
                    Bye
