Proper usage of VRayAlpha in Photoshop CC
  • Proper usage of VRayAlpha in Photoshop CC
    So how do I use the VRayAlpha element in Photoshop CC without getting fringes? I usually render on black and use the integrated Alpha of the EXR, I was just wondering if there is a way to properly use the VRayAlpha without getting fringes.
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    Intel Core i7-4930K @ 3.40 GHz
    NVIDIA GeForce GTX 780 (4096MB RAM)
    64GB RAM
    DxDiag
    I have not tried it, but likely this is just a result of the image being premultiplied with black.
    Load the alpha selection. Float that to a new layer (new layer via copy). Hide the underlying (original) layer, or delete it. Select the layer you just floated with the selection, which will have a slight black fringe. Make sure you have nothing selected, and go to Layer->Matting_>Remove Black Matte.
    This is the old way to unmultiply an image in Photoshop, before PS started supporting and interpreting some alpha as what it calls "Layer Transparency."
      Holy sh** I totally forgot about those layer options! Mainly because in the german version of Photoshop the naming of those functions are just awful. But it worked as expected.
      I copied my alpha into a mask for the RGB Layer, applied the mask, then did the Remove Black Matte thing.
      Software:
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      64GB RAM
      DxDiag
