VRayStereoscopic Helper Script
  • VRayStereoscopic Helper Script
    He guys and Dev Team,
    I wrote this quick little script to add a stereoscopic helper to a scene and link it to a camera somewhat logically. It parents it to the camera and links up the eye distance and focus distance parameters to the camera. This makes managing camera selection and keying easier by default. Make a camera selection and run the following code to try it out. Improvements welcome. I think there should ultimately just be a simple stereoscopic roll-out on the physical camera, where all the stereoscopic parameters can just reside and the helper isn't needed. I presume it is separated because of some weird max back-end stuff.
    Here's the code:
    Code:
    selectedItemsArray = selection as array
    for i in selectedItemsArray do
      if (SuperclassOf i == camera)then (
    	print ("Camera Found.... proceeding to add a node to "+ i.name +" and link some parameters.")
        --Create Stereo Node
    	VRayStereoscopic isSelected:on
    	$.parent = i
    	in coordsys parent $.pos = [5,0,0]
    	$.rotation.controller = SlaveRotation ()
    	$.name = i.name+"_stereoNode"
    	theStereoNodeName = $.name
    	$.interocular_method = 2
    	$.focus_method = 0
    	$.show_camera_cones = 1
    	the_stereoData = attributes stereoData
    	 parameters main rollout:stereoParams
    	  StereoEyeDistance type:#float Align:#Center  ui:StereoEyeDistanceSpinner default:6.5 Range:[-100,100,6.5]
    	 rollout stereoParams "StereoParameters"
    		spinner StereoEyeDistanceSpinner "StereoEyeDistance" type: #float
    	custAttributes.add i the_stereoData
    	paramWire.connect2way i.baseObject[#specify_focus] $.baseObject[#specify_focus] "specify_focus" "specify_focus"
    	paramWire.connect2way i.baseObject[#focus_distance] $.baseObject[#focus_distance] "focus_distance" "focus_distance"
    	paramWire.connect2way i.baseObject.stereoData[#StereoEyeDistance] $.baseObject[#eye_distance] "eye_distance" "StereoEyeDistance"
      )else (print "No cameras in selection!")
    I found this helpful and wanted to share.
    -Joel E
    https://www.biglittlepictures.com
    So I have found that this, because of the parenting of the stereoscopic camera helper to the camera, actualy doesn't work when distributed rendering. The external buckets are all wrong. Unparenting the helper corrects the problem. Perhaps I will just wire the position and add an offset value.
    -Joel E
      This works better and is error free.
      Code:
      	iPos = [i.pos.x + 6.5,i.pos.y,i.pos.z]
      	$.pos = iPos
      	$.pos.controller = Position_Constraint ()
      	$.pos.controller.RELATIVE = on
      	$.pos.controller.appendTarget i 100
      	$.rotation.controller = LookAt_Constraint ()
      		$.rotation.controller.upnode_axis = 1
      		$.rotation.controller.target_axis = 2
      		$.rotation.controller.StoUP_axis = 1
      		$.rotation.controller.target_axisFlip = on
      		$.rotation.controller.appendTarget i.target 100
      	$.focus_method = 0
      -Joel E
