Vray3 maxscript full expert
  • Vray3 maxscript full expert
    When reloading an old scene (vray2) all panels in vray3 are set to 'Basic', even if our maxstart or previous scene is all 'Expert'.
    Is there a maxcript command to turn all panels in 'expert' each time we load a scene, automatically ?
    An option to even totally disable these mode and being back to full expert always would even be better.
    Regards,
    Kib
    Apart caustic param that doesn't do anything, other works :
    Just put this in a startup script:
    function setVRayExpert =
    vr=renderers.current
    vrName = vr as string
    if findString vrName "V_Ray_Adv_3" != undefined then
    rdropen = 0
    if (renderSceneDialog.isOpen() == true) then rdropen = 1
    renderSceneDialog.close()
    vr.gi_ui_view = 2
    vr.irradmap_ui_view = 2
    vr.lightcache_ui_view = 2
    vr.caustics_ui_view = 2
    vr.colormapping_ui_view = 2
    vr.system_ui_view = 2
    vr.options_ui_view = 2
    if (rdropen == 1) then renderSceneDialog.open()
    clearlistener()
    callbacks.removescripts id:#VRayExpertPostLoad
    callbacks.addscript #filePostOpenProcess "setVRayExpert()" id:#VRayExpertPostLoad
      Vlado if you read this, could you confirm vr.caustics_ui_view bug ?
        No, it's not a bug. The caustics rollout only has an Advanced state, but not an Expert one. So you need to set it to 1, not 2.
          Ahah didn't see that, ok my own ! Thanks
