Reduce Noise when using UNIVERSAL settings?
  • Reduce Noise when using UNIVERSAL settings?
    Hi all
    When using UNIVERSAL settings, is the only QUICK way to reduce noise, to lower the noise threshold?
    I know there are other ways when you're NOT using universal, but in this case I want to know specific for universal.
    Kind Regards,
    Morne
    Depends on where the noise is coming from, but you can try increasing the min. shading rate in V-Ray 3
      It seems mostly from GI
      (Vray 2.4)
      Kind Regards,
      Morne
        Then you can try increasing the GI subdivs perhaps?
          I've got Global subdivs multiplier on 0 for this one ( min samples 8 )
          Kind Regards,
          Morne
            What GI setup you are using ? Irr map, LC or Bruteforce?
            Tashko Zashev | chaos.com
              BF primary, LC secondary
              Kind Regards,
              Morne
                For V-Ray 2.x the only way I think is to lower the Noise threshold value and force more camera rays to be traced.
                As vlado mentioned above , in V-Ray 3.0 there is an option "Min Shading rate" which could help.
