Vray Toon and Vray Clipper
  • Vray Toon and Vray Clipper
    Short question: Is it possible that vray toon isn't compatible with the Vray Clipper object? It seems that Vray toon is still outlining edges of clipped areas. Which by itself creates an interesting effect but sadly not what I need ;P
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
    Yes this is a known limitation of VRayToon and VRayClipper. It is in our "todo" list to fix it.
    Best Regards,
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Thanks for the answer. Is there any known workaround?
      Cheers,
      Oliver
        The only workaround that I can think of would be to attach all objects into a single polymesh, then apply slice modifier with Remove Top or Bottom option and then apply Cap Holes modifier.
