Vray 3 Render Node on License Server
  • Vray 3 Render Node on License Server
    Hi - sorry for the dumb question: In Vray 3, can a license server be a render node at the same time? If so, what option do you use in the initial install? I tried workstation mode and it deletes any option to run the license server in the ChaosGroup menu
    Cheers
    I had this problem too, I think you go into Chaos Group's website and under downloads there's license server. Grab that and install it over top of a vray render slave install.
    Brendan Coyle | www.brendancoyle.com
      Thanks Brendan - I'll give it a try
        There is a installation type called License Server Only:
Name:	2014-07-03 11_01_36.png
          Yes, the problem is that it will try to uninstall the render server part of V-Ray from the previous installation.
            Thanks Svetlozar. I did try that, however this does not give you the ability to run Vray Spawners at the same time ("Distributed Rendering" won't be in the Chaos menu). As Brendan suggested, I installed as a render node first and then installed the stand-alone License Server utility over the top, and that did the trick. BTW the installer internet links don't work
              Hi Bruce,
              Thanks the update.
              I just checked all four download links (32/64bit) of the license server an they work fine. Can you give me more details about this problem? Do you get any errors ?
              I see that you are located in Australia.
              Tashko Zashev | chaos.com
                Hi Tashko
                I just re-installed to check if those links worked - and they did. There must have been some network issues at my end during the previous install. Sorry about that
                  Originally posted by Bruce Hart View Post
                  Hi Tashko
                  Thank you very much for your update.
