Universal weirdness with VRay 2.5 - BF and LC
  • Universal weirdness with VRay 2.5 - BF and LC
    Hi all
    OK So I have some weirdness using universal. With the standard universal, I get a lot of noise in the GI, everything else is pretty clean. If I push BF to 200, the GI cleans up nicely, and the overall beauty is nice, but the the reflection element is MUCH noisier?!?
    Why is this?
    Kind Regards,
    Morne
    The higher I push BF, the worse the Reflection Noise gets. In LC tried with use for glossy on and off, still noise
    At 1024 BF subdivs, the reflection is going NUTS
    Kind Regards,
    Morne
      Hi Morne,
      Do you get more noisy reflections in the beauty in this case or only in the reflection element?
      Would it be possible to post render examples or even a scene file ?
      Tashko Zashev | chaos.com
        Originally posted by tashko.zashev View Post
        Hi Morne,
        This is at 200% zoom:
        The beauty looks ok(ish) with BF = 1000, but the rendertimes are WAY more than BF=8. This is with most of the heavy stuff hidden.
        Kind Regards,
        Morne
          Ah I see now, it will be better to send the file to our support mail in order to investigate further.
          In simple scene setup this issue doesn't persist. Thanks in advance.
            Thanks Tashko, I've sent a simplified version of the file (Max 2015 vray 2.5) to vray@chaosgroup.com and also to support@chaosgroup.com
            Kind Regards,
            Morne
              Thank you for the scene file. According to our tests there is no issues at all. Generally the sampling always works in respect to the beauty pass and adding more samples to the GI V-Ray decides to use less for reflections. It is due to the higher Noise threshold used and Adaptive DMC sampler.
              So if you want to clear the reflection pass up, you may need to increase a lot the material reflection subdivisions.
