It is taking forever to transfer my irradiance map to my slaves. My current scene is taking about 20 minutes, which means I don't see a slave bucket until the irradiance map gets there. What could cause this? Or, is this normal?
Slow to start on slaves
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
some slaves are taking even longer. A couple joins after 20 minutes, but two others take 30 minutes.Bobby Parker
phone: 2188206812
- Windows 11 Pro
once it is transfers, it starts pretty fast.Bobby Parker
phone: 2188206812
- Windows 11 Pro
What is the size of the Irr.Map?
How many machines participate in the DR?
What is the speed of your network?
Is there any improvement if you are rendering with only 2 or 3 machines?
What type of Irr.Map you are using for Fly-Through animation (single file) or for Animation (multiple files)?
Which Vray version you are using?
Is the issue scene dependent? Have you tried to render another scene with similar setup?
3 of our render nodes always take a lot longer to start than the others - nothing like 20 minutes though. Its a pain though. The 3x slow machines are all the same 6 core i7 with 32GB. The ones that kick in immediately are all 4 core i7 machines.Kind Regards,
Richard Birket
http://www.blinkimage.com
I would need to pre-calc the irmap to see if there is still a delay. We tend to use DR with a shared IRmap calculation.Kind Regards,
Richard Birket
I just to have that problem but in my case the reason was loading textures and files so my slaves have a local drive with all the maps and proxies or at least most of them.... Inside my project folder a have a sub folder for custom textures for that project.... They pick pretty quickly and I'm not often using pre-calculated Irmap or LCmap.show me the money!!
That's my setup, too, but still slow.Originally posted by flino2004 View PostI just to have that problem but in my case the reason was loading textures and files so my slaves have a local drive with all the maps and proxies or at least most of them.... Inside my project folder a have a sub folder for custom textures for that project.... They pick pretty quickly and I'm not often using pre-calculated Irmap or LCmap.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I assume this occurs only with specific scene? Could you try with different Irr map mode (precalculate and render)?
If you use Irr map Animation prepass mode, each render node need to load 5 .vrmap files (assuming Interp. frames is set to 2)
The issue seems to be related to the GI maps and their transfer, so few tests with different GI setup might be helpful to localize it.
Aslo as Svetlozar already mentioned above, it is important to specify :
My network speed
671.4683920 Mbps
This is from my main PC to my slaves.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I have recently discovered that if you only have the specific servers you are doing DR on ticked in the DR 'settings...' box then it speeds up the start of the rendering process quite significantly. If there's a bunch of DR servers in there ticked that aren't on, or are otherwise busy, vray takes a while working through the list figuring out what servers are available and what aren't.
