Autodesk Generic Materials to V-Ray?
  • Autodesk Generic Materials to V-Ray?
    Hello,
    I have a large Revit project that imported with all Autodesk Generic Materials, can these be converted to V-Ray? The scene converter does not seem to work with them. I usually create new shaders but this one has about 300+ materials and I only want to create new materials to the objects in view the rest is all background.
    I would appreciate any help!
    Eric
    "I have not failed. I've just found 10,000 ways that won't work."
    Thomas A. Edison
    converting works for me. Are you using V-Rays convertor, or a 3rd party script? I use V-Ray's and it converts Revit materials fine.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      I'm using V-Rays convertor...I've seen Arch & Design and Architectural but these are "Autodesk Generic" and it doesn't seem to work.
Name:	AutDesk Generic.jpg
      Thomas A. Edison
        I usually use this...works quite well, but I am not sure there is any support or contacting the developer (at least for me.)
        However, I have not tried it yet with these "Generic" materials.
          All the materials come in as Multi/Subs could that be it?
          Thomas A. Edison
            Bobby - Unless I'm mistaken, the vray scene converter only converts standard materials to Vray. It won't convert Revit Autodesk materials. Can you expand on what you are doing there? I'm not talking about A&D materials BTW which are translated to vray at render time
              http://www.scriptspot.com/3ds-max/sc...multyconvertor
              This scripts seems to convert the Generic Mtl to VrayMtl but unfortunately it doesn't preserve any properties like attached maps, colors, etc.
                but, for $75? You would think this is something that can just be done nativly.
                Originally posted by eyepiz View Post
                I'm using V-Rays convertor...I've seen Arch & D convertor...I've seen Arch & De
                [ATTACH=CONFIG]20529[/ATTACH]
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  I tried everything...only the $75 converter partially worked. It only converted about two third of the materials and error'd out, a real pain when you have 300 of those generic materials in a scene. I ended up doing most of them manually.
                  Thomas A. Edison
                    you would think that there was a simple solution.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      just necro'ing this thread. is it not about time that the vray converter was updated to support more material types? id say the ability to reliably convert every common material type would be a more important new feature than many. it still completely ignores autodesk generic materials, which, given the fact they crop up in almost every model i receive from an architect, and their generally *generic* nature, they should be relatively simple to auto convert.
                      ideally id also love to see octane materials supported, since personally i work with people who use octane, and they seem to have almost no problem converting from vray to octane.. is it so hard the other way?!
                      seems to me, allowing people to easily convert *away* from your product, but not providing a pathway to move *to* your product would be undesirable to say the least.
                      i know there are various third party converters (none which work with octane iirc) , but this should be a vray feature.
