Maxscript set current renderer to VRay? or set defaults?
  • Maxscript set current renderer to VRay? or set defaults?
    Hi all
    I want to load DEFAULT vray settings with maxscript. I don't see a way to load defaults so I'm setting the current renderer to scanline to wipe any user settings and then I want to set it back to VRay
    So with maxscript to switch to scanline is the easy part.
    How can I switch the current renderer to VRay? (no matter what version the user has installed)
    Kind Regards,
    Morne
    Nevermind
    Thorsten has the answer:
    http://forums.chaosgroup.com/showthr...196#post567196
    Kind Regards,
    Morne
      For the current renderer, you can click on the "Save As Defaults" button in the 3ds Max "Assign renderer" section.
      For the default settings of V-Ray, for the moment you can use a maxstart file. Future versions of V-Ray also allow you to save a V-Ray preset with the name "default", which will be loaded when a new scene is created.
        I'm busy with a specific script that needs to overwrite anything the user has done. Without setting EACH thing, the quickest way seems to be to switch to scanline and back to VRay
        Kind Regards,
        Morne
          Actually you don't need to set the renderer to scanline first. Simply typing
          Code:
          renderers.current = vray()
          will reset V-Ray to its default settings.
          Dan Brew
            Code:
            Sweet. Good stuff, thanks Dan!
            Kind Regards,
            Morne
              I don't know if this is of any use to you but like any constructor you can also set any of the parameters on creation. For example:
              Code:
              renderers.current = vray gi_on:true gi_secondary_type:3
              will reset V-Ray but turn on GI and set the secondary bounces to light cache.
              Dan Brew
