Setting VRIMG via maxscript results in 2 files
  • Setting VRIMG via maxscript results in 2 files
    Hi all
    If I set the vrimg file via maxscript (no matter if such a file currently exist or not), it creates 2 vrimg files with almost the same name
    for example myfile will save as
    myfile.vrimg (only 1KB big)
    and also myfile0000.vrimg (the actual image file)
    Code:
        RAWFile = getSaveFileName caption: "Save V-Ray image file" \
        filename: "C:/_VRay RAW Renders/" \
        types:"V-Ray image files (*.vrimg)|*.vrimg"
        if RAWFile!=undefined then
                rc=renderers.current
                rc.output_saveRawFile=true
                rc.output_rawFileName = RAWFile
    Kind Regards,
    Morne
    Hmm. When is the myfile.vrimg created?
      I do
      max quick render
      directly after that code
      and the 1kb file gets created just before the render starts it seems
      the other actual file gets created when the render starts and increase as usual in size as the render progress
      Kind Regards,
      Morne
        Hello
        The first file is created because of the line:
        Code:
        tmpbm = Bitmap 10 10 fileName:RAWFile
        in the example I sent you in the other topic. It was part of a script I wrote a while ago and I see now that later after the rendering I do:
        Code:
        deleteFile outName
        which deletes the small file and leaves only the one with the frame number. Probably I should look for some better solution to the first problem..
        Yavor Rubenov
        V-Ray for 3ds Max developer
          Originally posted by yavor.rubenov View Post
          Hello
          Code:
          Code:
          deleteFile outName
          OH OK I didnt realise they were related
          Thanks for now I will go with the
          deleteFile outName
          option
          Kind Regards,
          Morne
            hmmm
            deleteFile RAWFile
            only worked one time, then it stopped deleting the file for any further renders
            Kind Regards,
            Morne
