noise and render time
  • noise and render time
    I am having a fairly simple scene
    For 1600X960 render it is taking 7 hours 41 minutes 12.3 sec which is insane
    Am I doing something wrong in my settings
    I am very happy with the render quality with my machine (AMD 2.13 processor with 32 GB of ram)
    Is this render time expected !!
    Please guide me is their any way to optimize the scene having the same quality render
    These are my render settings
    Adaptive DMC with Min 1 Max 20 color threshold 0.005
    Global DMC sampler Adaptive amount 0.65 noise threshold 0.005
    I am using vray 2.40.03 with max 2013 following LWF
    I have attached render elements and the final render
    That is indeed a long time. Try DMC with 1 - 8, and threshold at 0.01 with DMC sampler noise at 0.008
    Also what are the subdivs for your lights/materials/...
    A.
    www.digitaltwins.be
      Thanks for the response
      My material subdivs varies from 8 to 256
      My light subdivs varies from 16 to 640
      I am using a dome light with 640 sundivs
      I tried your settings (DMC with 1 - 8, and threshold at 0.01 with DMC sampler noise at 0.00
      it is not cutting down the noise
      I know that the light and material subdivs are way too high, if I try to lower it is introducing noise
      kindly suggest me if their is any work around
        you don't need materials to be that high. That's why your render time is so long. For the gi, what kind of primary/secondary gi do you have? Using lightcache / for glossy rays and retrace might speed things up.
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          I am bruteforce and light cache
          brute force 128
          light cache with 2000 subdivs, prefilter -100 use for glossy rays is ON
          As I said before reducing the material settings is introducing lot of noise
            whenever you use brute force the render time will be high, there is no way around that.
            I suggest irradiance map, you can get better quality a lot faster.
            Dmitry Vinnik
            ShowReel:
