BSP tree parameter guide?
  • BSP tree parameter guide?
    I was wondering if there is any rule of thumb on what settings to chose for the BSP tree.
    Maybe based on render resolution, scene face count, object count, etc.
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    Intel Core i7-4930K @ 3.40 GHz
    NVIDIA GeForce GTX 780 (4096MB RAM)
    64GB RAM
    DxDiag
    It works pretty well regardless of those quantities. The only things you might want change are the max. depth and the faces/level coefficient and they have a direct influence on the render times vs memory usage.
    If you are using Embree, it ignores these settings and is fully automatic.
      Okay, cool. Didn't know it doesnt influence anything when using embree. On a side note - is there ANY argument against using Embree apart from not having intel CPUs?
      Software:
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      64GB RAM
      DxDiag
        Embree is a bit lower precision so very rarely, there are artifacts. There is also a slight instability in the official builds if for some strange reason an invalid ray direction is generated. Usually, none of these is a problem though. The second issue is fixed for the SP, where we have also extended Embree to handle V-Ray proxies and instances (and hopefully hair, but this is not certain yet as that part of Embree is still under active development).
          Interesting. Presume this means that in the near(ish) future we should see some further speed boosts using Embree and proxies and instances? I use it on all projects currently - never found a reason not to.
          Alex York
          Founder of Atelier York - Bespoke Architectural Visualisation
          www.atelieryork.co.uk
            Any estimate on the SP I'm eagerly waiting for GGX
            A.
            www.digitaltwins.be
              This is the case, indeed
                It's coming...
                  Wow okay, my scene is pretty much ONLY VRayProxies at the moment.
                  Does that mean that basically the Embree doesn't do anything?
                  Definitely nice to have it work with VRayProxies!
                  Software:
                  3ds Max 2016 SP4
                  V-Ray Adv 3.60.04
                  Hardware:
                  64GB RAM
                  DxDiag
                    Originally posted by Art48 View Post
                    wow okay, my scene is pretty much ONLY VRayProxies at the moment. Does that mean that basically the EMbree doesn't do anything?
                    Unfortunately in the official builds, Embree is not used for proxies yet.
                      As I didn't know this I did some tests.
                      Number 1: 2m56,6s : Array of a VrayProxy (=1 teapot) + EMBREE On
                      Number 2: 1m31,0s: Array of a Teapot mesh + EMBREE OFF
                      Number 3: 0m56,8s: Array of a Teapot mesh + EMBREE ON
                      BF + LC
                      AA 1-6 and 0.02 noise threshold
                      Min shading rate at 16
                      BF, materials, VraySun at 8 sbdvs
                      DMC multiplier at 0 and noise threshold at 0.015
                      Number 2 and 3 are as expected. But I expexted number 1 (with proxies) to be between 2 and 3 not twice as long. In the beginning of the LC it took quite some time to show more or less image. Maybe a nice thing to add at the end of a render is some statistics. How long the precalculations took, the LC, the BF, total. What settings. Some other usefull stuff, with some graphs. How many pixels needed the highest amount of samples etc. And this could be compared to other renders of the history.
                      A.
                      www.digitaltwins.be
                        So do we conclude from your test that, currently, if you are using proxies you should definitely turn OFF Embree? Looks like it....
                        The only test you didn't run was Number 1 but with EMBREE Off. It would be good to compare that against the EMBREE On.
                        Alex York
                          No, it only means that you should not use proxies just for instancing Regular instances are definitely faster than proxies. Proxies are only meaningful when you have a lot of geometry in your scene and you are looking for ways to reduce memory usage.
