I'm getting some nasty noise from a high res HDRI map in a dome light. I'm using IR/LC. The light is set to 128 subdivs. Also, I have an instance of the map in the environment slot. Anyhow, I'm looking at a 6hr. render and am wondering if upping the subdivs is the thing to try, or do I need to mess around with the dome light somehow?
Lighting Noise using HDRI in Vray Dome?
David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2024.2.1 Update
V-Ray GPU 6 Update 2.1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAMTags: None
There are no double faces that I can see. What I did discover is that a couple material subdivs were still on the default of 8. So bumping those up helped.
I set the Clr Threshold value down to .01 which certainly took care of the noise issue, but increased the render time 3-4x. I then took out the HDRI map and yes, that also helps with the noise issue.
In the end, I think I'm going back to the VRaySun / Skylight portal system until I can figure out how to best optimize using a single HRDR dome light.David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
I found an adaptive amount of 0.85 too low in most cases when going into high subdivs. I mostly have it at 0.95 to 0.98. It could lead to artifacts in low contrast or shadowy areas, but maybe try that since it casts fewer minimum samples into the scene. Its propably not the main source of your issues, but I guess it can help to some degree. Know what you are doing though. Read up on the adaptive amount if you're not sure what it does.Software:
Windows 7 Ultimate x64 SP1
3ds Max 2016 SP4
V-Ray Adv 3.60.04
Hardware:
Intel Core i7-4930K @ 3.40 GHz
NVIDIA GeForce GTX 780 (4096MB RAM)
64GB RAM
DxDiag
