101 question bump map question for a Brain Dead moment.
  • 101 question bump map question for a Brain Dead moment.
    Hello and thanks for your time,
    I'm having challenges mapping on a fine noise bump map onto a surface!
    I have a large multi-quad plane surface with a small relief-like design that pops out of it on the depth or Z-axis. If the plane is 10 x 10 units large, then the depth height of this relief is about 0.1 units high! Very soft relief but clear and obvious.
    I want to create a sand blasted-like texture onto it and part of the material solution is to use a noise map with a fine grain size in a Vray mat. Eventually I will use it for rendering still images and animations of the object moving about.
    The problem: I cant get it too look good! It does not map smoothly across the surface. If I use Explicit mapping with Box, my UVW are 10:10:10 (even though my plane is 10:10:0.1). This applies the noise all across the relief but in a muddy way. If I lower my W value, then I will be missing noise pattern on the relief. If I use Object mapping with Box, with UVW at 10:10:10 it looks a little better but I if I animate the plane moving or camera view, then noise pattern moves around in object space and you get that strange moving shimmery effect to the noise. If I use planar mapping (so 10 x 10 x 0), then there are missing areas of noise pattern where the Z-heights are more angular and higher and the noise starts to swirl around and look bad.
    I just want to map a fine noise pattern that looks good a very low relief model in a very smooth and consistent way ( as if the noise pattern was nicely draped over the relief geometry) and have it look good in the lighting and stay put!
    What am I doing wrong? Are there better solutions?
    Pop up some test renders of what you mean but I suspect this is an anti aliasing problem really. The issue is that a very fine bump map to the anti aliaser looks very similar to noise, which ultimately it's trying to smooth out. What might even be worth a look is rather than using a noise map which has infinite resolution, use a really high res texture of noise which will eventually run out of detail and allow the renderer to resolve it.
      That could contribute to the problem. My test renders at low res and just 1/4 Area looks rather smooth and acceptable. But when I up it to 1/6 Area with DMS on, I notice the artefacts of the noise pattern even more. but I do like your idea of placing a high res TIFF of a noise texture in the bump channel instead of a procedural.
        Might be a totally crazy idea but would it be worth actually exploring rendering the tiny bumps? If you have something like forest pro it might be worth a look? There's a discussion about sparkly materials happening at the minute and some people are trying to use things like tiny particles to represent the little bumps and imperfections in a surface - they're getting really good results and it might be actually easier for vray to resolve too!
          Is that technique being discussed in a thread on the forum here or maybe on the Forest Pro forum? I couldn't see anything obvious. Sounds interesting.
