VrayEdgesTex and Bump Map?
  • VrayEdgesTex and Bump Map?
    What's the best way if I need to use the two combined in the bump channel?
    Thanks.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    A Mix map or VRayCompTex should do it, I think.
      Thanks.
      I use a composite map and add the VrayEdgesTex as an addition on top of the bump map.
      "I have not failed. I've just found 10,000 ways that won't work."
      Thomas A. Edison
