3D Floor Plan
  • 3D Floor Plan
    I have to do one of those 3D floor plans. How do I render without seeing the ceiling, but the ceiling needs to block the sun.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I'm super curios about this too. I seen this done on the evermotion scenes. but the few I purchased there was no examples on how they did it.
    "I have not failed. I've just found 10,000 ways that won't work."
    Thomas A. Edison
      It has to be easy. I was thinking the camera clipper, but I need these at a South East orientation.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        use the VrayClipper, and turn on Camera rays only
        Brendan Coyle | www.brendancoyle.com
          Just set it to not visible to camera but leave cast shadows on.
          Alex York
          Founder of Atelier York - Bespoke Architectural Visualisation
          www.atelieryork.co.uk
            Now, that makes sense! Thank you!
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              But, on an angle that would not work.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                It should work fine but keep an eye on GI contribution. What you might need to do is make a copy of the ceiling object that affects GI, so you don't get lighting issues. Should work ok though.
                Edit: here are a few we did recently: http://atelieryork.co.uk/Buckley-Building-Axonometrics
                Alex York
                  What do you mean? If the camera is on angle?
                  The VrayClipper is a separate tool from the camera's clipping plane function. But yeah, setting objects to not be visible by camera is another great way to do it.
                    I'll work through it, I am sure it's pretty easy; I see them all the time.
                    What do you mean? If the camera is on an angle?
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      I usually use the slice modifier. I make a copy of the walls with the ceiling attached. I apply a slice to both remove top of one remove bottom of the other. Then the one I removed the bottom on (top of walls) and in obj properties turn that non-vizable to camera. That way it still casts shadows and I get a black top of walls which I like. Vray Clipper may be quicker.
                        Turned out to be pretty easy.
Name:	55 W Wacker Floor Plan.jpg
                        I set the ceiling not to be visible by the camera and left shadows on, exposed the camera for the exterior, and added a large v-ray light over the entire inside. Also, I capped the outside wall.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
