Rebus Farm and render mask
  • Rebus Farm and render mask
    Does anyone know if Rebus Farm fully supports render mask? I know if using back burner you must use layers instead of selected which is fine but just wanted to make sure Rebus is the same.
    if we render such a job we get a popup "no valide obj selected" (or such)
    answere is no
    for the layer i am not sure - if it work in BB it should be ok here too
    will do testings next week
    __________________________________
    - moste powerfull Render farm in world -
    RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
    just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
      The object selection is not saved in the 3ds Max files, so this can't work. You will need to use some of the other methods to specify the objects to mask.
