just looking for advise on a material idea
  • just looking for advise on a material idea
    Hello and thanks for your time,
    I'm trying to make a material that looks like the attached image. This is the best example I can find.
    Basically there is a cruddy or oxidized patina around the outside and corners of all the form with a relatively cleaner and shiny surface outside it.
    any ideas?
    http://firstcoincompany.com/image/ca...Kb-900x900.jpg
    K
    Just use vray dirt as a mask and mix two different color/textures together. It will produce this result.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      i did try that. It did not give me enough range or falloff showing the crud material. also it is brutally long to render. was hoping there was a quicker way
        Bake few different AO to texture then blend in PS then use it in max.
          Can you show us what you've got so far, screen-shot or a scene?
          VrayDirtTex will slow down the rendering a bit but it should not be brutally long unless subdivs value is too high.
